Old 02-27-2011, 03:50 PM   #14 (permalink)
frankydevaere
Okay, if the cylinders rotate in one direction, and the crankshaft rotates in the other direction, and the "heads" are stationary -- where is the power output shaft?
It fell off. No honestly, the engine can be applied in hybrid applications or generators. One can choose form where to take off the torque : cranshaft or cylinderbank
See FAQ on the white pages of the portal website : http://www.wix.com/devaere/radial-bi-rotary
"Is this engine suited for generators or green technology hybrides ?
Cylinderbank and crankshaft has a 1 to 5 ratio. This means that a engine ideal designed and running at a fix full throttle has very interesting rpm-configurations.
A crankshaft running at 3000 rpm has the cylinder rotor running at 600 rpm, 6000 rpm crankshaft correspond with 1200 rpm cylinderrotor. These are all very interesting AC-electromotor rpm's."
Would it be simpler to have all four pistons on straight/conventional connecting rods?
Then you loose the balance concept. This is a naturally smooth engine design, because all rotating and reciprocating parts are equalized with each other , without creating any rocking couple or torsional vibrations.
Further, in a configuration with conventional conrods, de cylinders are not in the same circular plane having the "open tops " in line, able to present themselves under the inlet or outlet gates.
