Old 02-27-2011, 09:43 PM   #4 (permalink)
Angmaar
Originally Posted by regor View Post
So the question is: Can I still shift the Elantra into neutral from drive while the vehicle is moving and shift it back into drive from neutral while the vehicle is moving without damaging the transmission.
Thanks!
Yes you will be fine doing that as long as you aren't "revving" the engine while switching. Just let it idle for a second or two before you switch between idle and drive.
