Old 02-28-2011, 12:26 AM   #2 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I think you would get better results if you used both packs at the same time because otherwise it's going to be like having two people on a tandem bicycle but they take turns pedaling, if they both work together they share the load/work and are not stressed as much, look at the battery specs, they give an amp hour rating for different discharge rates, discharge faster and you get less and the batteries over all life is shorter as well.
