My guess is that it is doing this to prevent stalling if the driver quickly changes load. If you leave in in neutral for a little bit does it return to stopped idle speeds?
Do you have a scan-gauge or something similar?
Instead of shifting to neutral if you are not stopping try shifting up and hold a low RPM.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
