If you have $70 burning a hole in your pocket to save money in gasoline, buy an Ultragauge and use it as a tool for improving your driving. The best trick for improving MPG is adjusting the nut behind the wheel. Otherwise the proven mods are block heaters, grille blocks, and aerodynamic modifications. Anything that plugs in or bolts on and promises 20%+ improvement is snake oil.
