google maps tells me that Lacey is 1126km [704 miles] away, and will take 12.5 hrs. This will be an exellent test run to see if all my work and "wishfull thinking" has turned into measured results. If I go the posted speed limit and can do better than 81mpg [2.9L/100km] for the full distance then it will be wearth going to the Vetter Challenge. If not then its back to the drawing board.
