Old 03-02-2011, 05:59 PM   #46 (permalink)
kawboyCAFE
NinFo - '09 kawasaki ninja 250R
Originally Posted by fjasper View Post
This site ( Watt_man on Xanga ) has some interesting info, including test results on an o-ring chain run for 34,000 miles using only WD40.
well, i would say the so-called report documenting this is bullcrap. WD-40 is one of the worst things you can use on an o-ring chain. it actually dries out the seals quicker, causing the chain to fail prematurely. this has been tested and proved time and time again.
