Old 03-03-2011, 10:12 AM   #2 (permalink)
Joenavy85
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
i'll give you an "A" for the concept of deflecting the air around the front tires and a "C" for execution of concept. I've dealt with polystyrene alot (i built tons of plastic model cars growing up) and i have to say it is likely too flimsy to suit your needs in this case. i would suggest finding some 1/16"(1.5mm) Plexiglass to use instead of the styrene. I'm sure the guys on here know of a few other materials you could use. it's a good start for what your looking for and it's a good thing to look at (i'm going to put something similar on the side of the airdam on my Jeep) since it should reduce drag caused by the tires
The Following User Says Thank You to Joenavy85 For This Useful Post:
caferacer51 (03-03-2011)
