Old 03-03-2011, 02:09 PM   #51 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
I have to admit, a generic O2 sensor and an inexpensive gauge while appealing to my cheap side will unlikely be as accurate as a more expensive wideband kit.
For my setup I have noticed that for my best flowing pipe the engine acted as if it was lean and the gauge showed it slightly lean. For the pipe I have on now it runs perfect and the gauge shows a little rich. This corroborates what I've read that ICEs can run well farther into the rich zone from stoich than into the lean zone.
I look forward to reading your results whatever you end up with. Sometimes some instrumentation is better than none, provided you can accurately interpret what information is provided by it.
Good design is simple. Getting there isn't.
