Old 03-03-2011, 06:08 PM   #13 (permalink)
aerohead
venting
Originally Posted by fastivab6tg25mr View Post
anyone?
It really takes a wind tunnel to do this correctly.
The 'safest' place is under the car,part of a bellypan.If you ever loose an AC line or radiator hose you won't be blinded when the refrigerant or coolant hits the windshield.
If you tufted your hood/cowl area you'd see how the tufts crowd the area around the A-pillars as the air races around those corners.The air is very fast here and pressure very low.This might be a place to let the air out and maintain safe visibility.
