Originally Posted by darcane
Do any of you have issues with the ultra-gauge missing a few of your miles? I've got mine calibrated, but occasionally it will vary off of my odometer by up to 1%.
I think the reason why is because I typically start my truck, immediately put it in gear, and get moving. I suspect it is "missing" a few clicks before it is totally booted up.
Other than that, I've got good accuracy on mine. I just filled up this morning with 30.7 gallons and it was reporting 30.7 used 18.85 actual mpg vs 18.9 reported.
Both UG and SG lose distance when rolling with the key in off position. If I drive my test loop with cruise control, the UG/SG show I've traveled 9.9 miles. If I drive the same loop with P&G, they show the distance as 9.6 miles.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
