Fran and Paul kindly put together some software for me to read and limit motor rpm. Seems to have a little weird side effect of causing the limit function to kick in at very low rpm if the serial communcation lead is left connected
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
