Pretty cool, Vacationtime! I kind of doubt it`ll handle interstates, even briefly, but should be no problem what so ever on any other roads, and I`d be VERY surprised if you don`t meet your 60 MPG goal. If you need some cargo capacity for it, check out the top boxes from JC Whitney`s motorcycle section. They run around $50 to $60 (two sizes) and are a pretty good value. By the way, enduros with 17inch wheels and smooth tires fall into a sub category that usually goes as "supermoto" or "motard" these days. Normally have lower seat height also, which is a great tradeoff (comfort and convenience over rock clearance and long suspension travel) for mostly street use. I hope you post back when you get some rideing to let us know how it`s doing for you. Have fun!
