Paul , Its not a problem with the serial lead disconnected or with the laptop hooked up. I just thought you'd like to see the results. Yes this is the 100ms code. The other code would have rattled the car apart
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
