Old 03-06-2011, 11:29 AM   #4439 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by MPaulHolmes View Post
PCB for the current sensor. I tested it with 3 different bus bar dimensions, and 0.125" spacing is perfect for all of them. So I can use that for anything from 500 amps up to about 1200amps, and if you add one more PCB spacer, it would be good to around 2000 amps. There's no limit to the number of amps it can monitor.
Hi Paul,
A $6.00 1000amp current sensor, that sounds great !!!
Would a smaller 0.062" PCB work with your 300amp per phase AC Controller ? (maybe a 300amp - 500amp range) ?
I would be very interested a couple of those !!!
Regards,
-Mark
