The Bauer-con is basically an igbt output stage. Some modifications to the control board will help such as using a dc dc with a 15v output and the little two resistor and ultra fast diode circuit posted way back to help with the turn off.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
