Old 03-07-2011, 11:26 AM   #14 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
You're missing a big part of the HX advantage - gear ratios. If you swap in an HX trans, you'll get a big highway boost. Even better is the 92-95 CX/VX transmission.
Aerodynamics will help a lot at those speeds.
Neutral coasting when you can will also help. Running the engine at 3000 rpm is a waste no matter what throttle setting you have. Idling at <1000 rpm is much better.
The Following 2 Users Say Thank You to PaleMelanesian For This Useful Post:
California98Civic (03-07-2011), j12piprius (03-07-2011)
