so by shrouding both,they would both see less oxygen then adjust fuel to get back to proper ratio but readings shrouded (leaner).
i currently have a computerchip on the iat sensor (warmer reading)
50% blocked iac port (to lower high idle)
still want to put in hotter thermostat
