Old 04-30-2008, 11:38 AM   #71 (permalink)
metroschultz
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
If you can't find any lowering springs you can always cut one (or 1/2) coil off the existing spring.
You need to replace the leaky strut anyway so you will already have it off.
I am sure you will do the dis-assembly yourself, so why not handle the spring issue then?
Heat is bad for springs so don't use a torch.
Cutoff wheel or hacksaw (if you want Popeye arms)
IIRC the Hondas don't have a flat end coil.
So all you have to do is re-align the perch.
I may be wrong though,
stay safe and do what you think is best,
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
