Old 04-30-2008, 10:44 AM   #52 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
With a better pump that would work. These are cheap constant speed, continuous running, variable output, pumps. It is a spring load piston setup where the spring provides the limited output pressure.
A fixed displacement, pressure shutoff pump would simplify things, but again at a cost.
Adding a pressure switch to the output of the cheap pump might just be close enough though...
