Old 03-07-2011, 03:18 PM   #9 (permalink)
zonker
500 Mile Metro Traveler
'89 Dakota LB - blue - '89 Dodge Dakota V6 LE
90 day: 19.8 mpg (US)
'17 Fiat 124 - SunFiat - '17 Fiat 124 Spider Classica
90 day: 30.51 mpg (US)
'89 Metro - The Egg - '89 Geo Metro Base
90 day: 50.71 mpg (US)
'94 Alto - The Box - '94 Suzuki Alto Ce-L
90 day: 39.5 mpg (US)
Originally Posted by old blue View Post
so by shrouding both,they would both see less oxygen then adjust fuel to get back to proper ratio but readings shrouded (leaner).
i currently have a computerchip on the iat sensor (warmer reading)
50% blocked iac port (to lower high idle)
still want to put in hotter thermostat
the scond O2 sensor is there only to determine if the cat is functioning properly, so I'd do the front sensor and then see if the car throw a code. If it does, you can then add the second shroud, or look for a cat MIL eliminator to wire inline with the O2 element.
