Old 03-07-2011, 09:31 PM   #4444 (permalink)
vwdevotee
Originally Posted by jyanof View Post
It's been implemented in the form of overspeed protection. It doesn't calculate a specific RPM, but calculates a number; if that number is above the threshold you provide, power to the motor is cut.
The calculation could probably be modified to produce an actual rpm value or a proportional PWM signal. It will be very inaccurate at low speeds and will also vary in accuracy at different output currents. For example, I noticed that the overspeed would trip at lower RPM if the motor was lightly loaded. The difference was small though, maybe 400 RPM between an unloaded motor and a highly loaded motor.
Also, no calculations are performed when you're coasting (since motor voltage is zero) so the tach would also go to zero. Might be a little weird to get used to...
Lastly, this calculation only works with series wound motors, hence the modifications required for Jack and his compound motor (i think it's a compound, anyway).
If you try it though, let us know how it works! I've had a dead tach for 2 years now...
btw, you can feed a traditional tach with the signal produced by a couple of magnets on the motor tailshaft (or shaft adapter, i guess) and a home made sensor of a couple hundred turns of fine magnet wire around a screw. Put the screw/magnet wire close to where the magnets pass and they will produce a voltage as they pass by. Use a 12v zener to clamp the output to 12V and feed it to your tach signal input. That's the jist of it, let me know if you want more details...
I had another thought while at work today, what about hijacking the rev counter for use as am ammeter? Instead of reading 0-7500 1/min, maybe set the scale to 0-750A. I suspect the hardware off the MCU wouldn't be to tough; maybe an isolated op amp to boost the pulse signal to something the rev counter will be able to read.
Originally Posted by jackbauer View Post
The Bauer-con is basically an igbt output stage. Some modifications to the control board will help such as using a dc dc with a 15v output and the little two resistor and ultra fast diode circuit posted way back to help with the turn off.
OK Jack. Do you have any pictures of your system? I'm curious about how you arranged your capacitor bank. After I read the rest of the ReVolt sub-Forum, I'm going to watch all of your YouTube videos.
