I could see an engine like the Honda Goldwing's working ok, 1,100cc to 1,800cc depending on the year, it's a flat 4 boxer set up for shaft drive and water cooling and is from a motorcycle that is designed to be able to be loaded down and towing a trailer where alot of motorcycle engines are designed for low load high revs.
