Welcome back!
What is your tire pressure? Have you considered some simple aerodynamic mods? Once your car coasts better, then you have to adjust your driving habits to take as much advantage of this as you can.
+1
I didn't see the mpg I thought I should see until I added 4 psi to the front tires.
Then all the sudden my mileage jumped a good bit. That measly 4psi took the tire from sidewall max of 44 to 48. Pretty darn amazing that small change made but I guess the tire needed it to roll better. Immediate difference in coasting!
Needless to say but soon after all my tires were at 50psi.
