Old 03-08-2011, 01:20 PM   #20 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by sawickm View Post
Hi Adam,
Did you reverse engineer the VLA-502-01 Powerex driver module? or is the Driver PCB you have shown in your pictures based on what the cougar driver power supply ??? Same pinouts as the Powerex VLA-502-01 PCB ???
Looking good !!!
-Mark
Hello Mark,
The driver module for the VLA-500 is basically the same circuit that they offer in the BG2A dev kit. http://www.pwrx.com/pwrx/docs/bg2a_application_note.pdf
It has some modifications to the board but not too many. I do plan to add hardware overcurrent protection like in the cougar as well. This will be good for those mishaps.
This will be directly on the main board so it can serve to protect the entire output. it wont matter what driver board is connected, because the pwm will stop before it gets to the driver.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
