Old 03-08-2011, 04:12 PM   #64 (permalink)
Frank Lee
Originally Posted by ktaylor View Post
That's true. Higher than the sidewall max puts you in the safety cushion set by the manufacturer. Realizing that tires heat up as you drive increases pressure is something to keep in mind also. The pressure in my tires has gone up by 5 psi after my 1.5 hour commute so I leave my tires 5 psi below sidewall max as a precaution. I'm leaving my motorcycle tires at the recommended rating though. Fuel efficiency on my bike is good enough for the girls I go out with lol
That is quite unnecessary. For one thing, mfgs have taken that into account and that is why they recommend only checking pressure on cold, undriven-on tires AND THEN they say DO NOT bleed tire pressure down if you check them hot!
For another thing, burst pressure is up around 200 psi so no, if sidewall max is 41 and it goes to 46, it won't blow up.
