Old 03-09-2011, 10:58 AM   #8 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Talking
Originally Posted by Joenavy85 View Post
what did you use to cut the disc's?
Being coroplast...a sharp Xacto knife. Carefully measured the rim and where the cover was gonna sit into. The diameter was slightly less than the Walmart pizza pan. I just held the pan down and cut into the first skin layer of the Coroplast. Pulled the pan off and then finished the cut. Used one of those Stanley shaver/planers to trim it down to size. To git the valve hole, I just pressed hard where the cap was and then drilled it out with a ½" drill bit. Primed it with plastic primer and then painted them with flat black paint.
My material of choice was those small political signs...I think they were 18" x 24". I have a ton of those from the last election. I could probably make 5 more sets.
