Old 03-09-2011, 12:39 PM   #41 (permalink)
bandit86
Buggie - '01 Vw Beetle TDI Gls
Originally Posted by alohaspirit View Post
interesting
is that glue or magnets?
The centre cap pops out, that's how the wheels are balanced when tires are installed. now all you would need is a a centering washer, also called cone, on the inside and the outside of the middle holel, and you could have a pefectly centered centre stud.
Once you have a perfectly centered stud, all you need ia a hole in the middle of the hubcap, and two nuts to mount the hubcap. If you want to get creative, you can use a connecting nut, basically a really long nut you can thread into from both ends, and use a fender bolt that is contersunk for perfectlt smooth, they even come stainless to match pizza pans.
The connecting nut might be doable on a wheel lugnut too, if enough is sticking out of the original studs. If not, all studs pop right out and longer ones are cheap enough if you buy a lot
This way, instead of wire ties and duct tape it will look more professinal, and people wont get scared off when they hear eco-modding.
