Old 03-09-2011, 01:56 PM   #9 (permalink)
gone-ot
...beats walking...
...I was just emphasizing the fact that although HP might not decline with E85-vs.-gasoline, the Fuel Economy certainly does.
...that is, unless (as you correctly state) the engine can actually "use" the higher octane value of E85, such as is possible with turbocharged engines...ie: they're "designed" to run on E85 and gasoline.
...and, just having a turbocharger is NOT enough, there must also be both wide-range sensors and programming capable of handling both gasoline (E0) and gasohol (E85).
