Old 03-09-2011, 06:51 PM   #6 (permalink)
GeneralAnarchy
Originally Posted by fjasper View Post
laack, sounds like yours is dead.
I've had some EBHs that just had a bad wire near the plug. If you hook up an audio continuity tester and wiggle the plug wire sometimes it will chirp.
Otherwise, you can take off the plug and test the resistance. If it goes to infinity then the break is probably in the heater itself.
