Old 03-09-2011, 08:21 PM   #8 (permalink)
fjasper
Bookworm
Sylvio 2 - '04 Audi allroad quattro Biturbo 6-spd
90 day: 25.09 mpg (US)
Atlas - '04 Audi allroad 2.7T 6MT
Originally Posted by GeneralAnarchy View Post
I've had some EBHs that just had a bad wire near the plug. If you hook up an audio continuity tester and wiggle the plug wire sometimes it will chirp.
Otherwise, you can take off the plug and test the resistance. If it goes to infinity then the break is probably in the heater itself.
Ha-ha, I had a paragraph suggesting putting a continuity tester across it to check it, but I deleted it before I posted. Worth a check for sure.
The latest one I had put in has a separate cord that plugs in to the heater unit. Another opportunity for an open circuit. Make sure the wire has enough slack to allow the motor to shift around without stressing the wires.
