Welcome to ecomodder.com .
Originally Posted by 2000_HX_Civic
It is also confirmed that the CPU isn't getting enough juice, it is reading 4 ohms instead of the necessary 12. So my Vtec-e isn't engaging and hence why I am unable to go over 4k rpm.
They are claiming I need a whole new ECU for $1200.
If its resistance isn't what it should be, the part may well be damaged.
At least you now know what resistance to look for in a good part, so I'd try the scrapyards for a replacement.
