Originally Posted by euromodder
As the exhaust gasses cool down along the exhaust pipe, why not harvest the heat a bit further down the pipe so it won't overheat the coolant ?
I guess the issue becomes the balance between getting enough heat early in the cycle without overheating the system in hot conditions. I like the breakable heat pipe idea. Simple, effective, and doesn't involve fluids that can leak, freeze, or react badly to heat. Would probably be sensitive to alignment and dirt issues, though.
