There are engine oil heat exchangers mounted at the oil filter inlet to hasten engine oil warm-up and to keep temps from spiking while underway (working hard or hard conditions).
This is from a police-spec Ford, and
here is a diagram from a Chevrolet.
MOPAR used to sell one that was simply a block filter adaptor with two lines for coolant ingress/egress, and ran to radiator and from the water pump. Used on early V6 minivans. Looked like
this.
