Old 03-11-2011, 12:02 AM   #81 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Originally Posted by PaleMelanesian View Post
At higher inflation levels, the tires tend to heat up less. There's less flexing in the sidewall to generate heat.
What tire pressures would you put in the following tires?
I would love to be able to put at least 50 psi in them. If so, should I work up to this gradually?
99 honda civic ex - 175/70 R14 84T
altimax RT general tire / max inflation 44 / max load 1102
89 chevy celebrity - 185/75 R14 89S M+S
front: douglas xtra-trac II / max inflation 44 / max load 1102
back: michelin X radial / max inflation 35 / max load 1290
89 chevy celebrity x - 185/75 R14 89S M+S
3: dayton quadra SE / max inflation 35 / max load 1290
1: douglas XTRA Trac A/W / max inflation 35 / max load 1290
