Old 03-10-2011, 11:46 PM   #203 (permalink)
George Tyler
Hi Orangeboy, I also have a Previa, does your solendiod take continuos 12V? I was thinking of using the O/D switch on the end of the gearchange lever, don't think anyone ever turns it off.... but then, maybe a relay that latches from a momentary action sw and releases when the brake pedal is pressed would be betterdo you know which 12V supply to the ECU is the right one to use for the supply to the switch?
