Originally Posted by Frank Lee
If a dinky featherweight bicycle tire can hold well over 100 psi I don't see why a car tire in good shape couldn't. That said, I don't like running car tires over 50 psi just cuzza ride harshness.
That assumes they are constructed the same - and clearly they aren't.
Bicycle tires are specified to run at much higher pressures than passenger car tires - as are medium duty truck tires (over 100 psi). This has to do with the strength of the materials in the sidewall.
Heck, the tires on the space shuttle are inflated to over 300 psi.
