Originally Posted by johnlvs2run
What tire pressures would you put in the following tires?
I would love to be able to put at least 50 psi in them. If so, should I work up to this gradually?
All I'll say is I have mine into the "margin of safety" range.
I backed down a little when the back end started skittering sideways on speed bumps.
