Old 03-11-2011, 12:19 PM   #620 (permalink)
Magister
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
received by email
I have tested the new release today. It seems to work okay, but the smoothing function seems to have some side-effects:
When the car is started but not moving the INST CONS is shown as L/100 and not as L/h as before the update. I’m not sure if the numbers are okay – but the units are not.
When the is moving and I push the clutch so the engine is in neutral, the INST CONS is showing 0.00 for some seconds and the it shows the idle consuming.
The smoothing seems to be working well, especially at constant speed (for instance at the highway). There it seems to be easier to read because the numbers don’t change all the time.
I’ll return to you if I observe other things – during the next week or so.
I’ve got a couple of new ideas:
It would be nice if you could choose the BigNum font as an option in the config menu – so you didn’t have to reload the code just because you want to change the BigNum font. It would also be very nice J if you could choose among all the numeric PID’s to be shown at the BigNum screen, for instance Speed or RPM – or whatever.
2013 Hyundai Sonata Hybrid
