I get it. That is verry true, for the Extremes of vehicle use and for aero.
I hadent really checked out enough to see the grille ideas. I have been working on the same idea for a while myself. Vacuum or motor actuated or even cable actuated. {I like electronics and building the circuts} So I hope to be able to contribute towards that!
The Pros and Cons are always waiging a battle royal when i do something to my truck. {like when i did a partial block for this winter, the only problem was my coolant started to leak a bit and i had to adjust. "Theory X application + test = results}
