I made a controller box for it, idea is what when I push a button it latches a relay, and a dab on the brake pedal releases it. works great. I see there is a problem in that there is no spring , a manual transmission has springs in the middle of the clutch plate to absorb vibration but the auto does not, so if the RPM drops to below 2000 the car vibrates terribly.
