Old 03-13-2011, 08:31 PM   #15 (permalink)
Daox
Originally Posted by vskid3 View Post
What about attaching a magnet to the bottom of the stick and have a reed switch in each of the gear positions? Then when the stick is in gear, it'll activate the switch for that gear, so when none are activated, it'll assume its in neutral. Then you could even have it act differently coming from different gears.
That would probably work fine. However, I don't think I'll need to differentiate between what gear its in, and I'd also have to mount 6 switches vs just drilling a hole for an LED and a hole for a photo resistor.
I've ordered all the necessary parts and looked over the ignition system schematics this weekend. It doesn't look like I'll be able to just activate the starter unless I bypass the clutch switch which I do not want to do. I could make it work, but it would require a bit more rewiring, and I'm not sure I want to do that yet as I'm not sure how great its even going to work quiet yet.
