euromodder, if you are living in a flat country then the cc will give you something hard to beat excepting by using P&G.
When using a steady speed, "hang time" is a great tool. After the speed is stabilized, just release a very little the accelerator : the consumption lowers but not the speed. You may repeat this until the speed lowers. I can do this 2 or 3 times on my wife's car before the speed lowers by 1-3km/h. At the same time the consumption lowers by 5-15%
When you are riding in such an optimized position then a simple car passing you or a very light uphill will make you slow down. You have to accept to continue your ride at a lower speed so you will not have the cc default : having to reaccelerate as soon as it looses some speed. Reaccelerate only other time and use downhills if any to do so.
Have fun,
Denis.
Save money & CO2 at home :
http://ecorenovator.org/
Created and managed by the creators of
http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
- 5725.5 kg CO2 (5342.6+382.9)
- Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane :
thread -
kill switch.
