Old 03-15-2011, 08:49 AM   #34 (permalink)
Joenavy85
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Originally Posted by htvfd460 View Post
Oh and the fluid doesn't flow to the cooler unless in gear, idling doesn't pump the fluid to the cooler at all. Only in reverse, drive and chosen gear does the ATF flow.
wrong, if that was the case you would have to be in gear when you start the truck, to get fluid into your TC. fluid flows any time the engine is running, hence why you don't want to EOC in most AT cars, but won't have any issues if you just put it in neutral
