Old 03-15-2011, 04:00 PM   #37 (permalink)
htvfd460
American - '06 Ford Ranger STX
90 day: 27.05 mpg (US)
Warning for all Dodge Rear Wheel Drive Overdrive Transmissions Except 45RFE
"#5. The fluid level is checked in neutral with the parking brake on. All Dodge rear wheel drive transmission have no fluid feed to the torque converter in park position unless you have a special valve installed in your transmission. The level will read higher in park than it actually is. All of the above information doesn't apply to the Dodge 45RFE. Read the stick on both sides and go by the side that reads the lowest. Always check the fluid level three times"
