That is right. On a turbo diesel manifold vacuum is bad. Diesels require high compression to get fuel to it's flash point, running at 18:1 like a Powerstroke isn't enough so the turbo needs to feed more air to reach over 21:1 for proper combustion. Even at idle there is no vacuum.
