Originally Posted by MaxHedrm
If you changed the rolling diameter of the tires your FE didn't go up as much as you think since the odometer thinks you are going further than you really are. Your speedometer is off too, luckily it reads faster than you are actually traveling, so you'll just get honked at and not get the police after you. :-D
By
mario_marques at 2011-02-01
This is my 5th gear with 15" wheels(not at redline but close), i also have digital meter in my car and i know how to calc gear rations vs wheel ratio
I still have the sixth gear, i can set the speedometer in vag-com for 15", 16", 17" or 18" wheels.
Tuned VW Golf Mk4 Tdi, Euro spec!
AJM engine swaped by ASZ and many other goodies
