Old 03-15-2011, 07:28 PM   #44 (permalink)
Joenavy85
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Originally Posted by htvfd460 View Post
Warning for all Dodge Rear Wheel Drive Overdrive Transmissions Except 45RFE
"#5. The fluid level is checked in neutral with the parking brake on. All Dodge rear wheel drive transmission have no fluid feed to the torque converter in park position unless you have a special valve installed in your transmission. The level will read higher in park than it actually is. All of the above information doesn't apply to the Dodge 45RFE. Read the stick on both sides and go by the side that reads the lowest. Always check the fluid level three times"
ok, i stand corrected. so can someone explain to me how the TC fills if it has to be in gear to pump. if you put it in gear and the TC can't transmit power how will anything else spin to pump the ATF into the TC?? or am I completely missing something??
