Old 03-15-2011, 07:06 PM   #63 (permalink)
Arragonis
The PRC.
Originally Posted by Polar View Post
I guess the logical thing to do then, would be to only fill her up half, and save another few 10s of lbs of weight. Which is what I used to do with my 2006 Fabia TDI. The weight gain can only improve your mileage, provided that you don't put in extra miles to drive towards your fuel station of choice. It won't be much, maybe half an MPG at most, but all little bits help.
Plus, of course, your shorter tank intervals should give you more tangible driving techniques vs. MPG results.
I don't consider having to tank more than once a month unreasonably frequent. Do you?
No I don't
Measuring MPG is easier tank to tank though as it gives you a standard point to measure against, and I have a choice (depending on price via the web) on where to fill up of about 2-3 garages under 3 miles from home.
