Old 03-15-2011, 10:39 PM   #21 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Angry
In Ohio
4501-43-04 Specifications.
(A) The horizontal bumper shall be at least 4.5 inches in vertical height, centered on the vehicle’s centerline, and extend no less than the width of the respective wheel track distances. Bumpers shall be horizontal load-bearing bumpers and attached to the vehicle frame to effectively transfer impact when engaged.
(B) Maximum bumper heights shall be determined by the type of vehicle at time of manufacture. If other than a passenger vehicle, the maximum bumper height shall be determined by the gross vehicle weight rating (GVWR) at the time of manufacture. The height shall be measured in terms of the vertical distance between the ground and the bottom of the bumper. MAXIUMUM bumper heights are as follows:
Bumper Height FRONT REAR
Passenger vehicles 22 inches 22 inches
All other vehicles
4,500 lbs. and under GVWR 24 inches 26 inches
4,501 lbs. to 7,500 lbs. GVWR 27 inches 29 inches
7,501 lbs. to 10,000 lbs. GVWR 28 inches 31 inches
(C) If the body and/or truck bed height is altered, the difference in height between the body floor and/or the truck bed floor to the top of the frame rail shall not exceed four inches.
(D) For any vehicle with bumpers or attaching components which have been modified or altered from the original manufacturer’s design in order to conform with the maximum bumper requirements of this rule, the bumper height shall be measured from a level surface to the bottom of the vehicle frame rail at the most forward and rearward points of the frame rail.
Frame Rail Height if bumper modified or altered Front Rear
All other vehicles
4,501 lbs. to 7,500 GVWR 27 inches 29 inches
(E) The height restriction in this rule applies to the distance from the ground to the bottom of the frame rail under any one or more of the following conditions:
(1) A motor vehicle is not equipped with a front and rear bumper.
(2) The bumper height relative to the frame rails has been altered.
(3) A supplemental bumper has been installed or an addition to the original or replacement has been made.
And for having a boat tail on an aerorabbit the tax is $90.
